Sometimes it starts, usually it doesn't. Replaced the power pack with new Mallory after trouble-shooting suggested it was bad (appeared to spark weakly when tapping on old power pack but not at all otherwise). Initially wouldn't start with new pack. Removed new pp and both coils and wire brushed all ground contacts. Reassembled and it started right up and ran great at idle and open throttle during a 30 minute ride . Killed and restarted repeatedly. Today, two days later, won't start. Blistered hand pulling and used cheater fluid (ether sprayed in carb). Started once after about 20 pulls but I stalled it putting it in gear and it never fired again after about 100 more pulls. Not even a burble. Gotta be spark. Plugs look great, slightly wet with fuel but no carbon (don't think its flooding with the ether boost). Plug wires are in good shape, though not new. Will test tomorrow night when I can get a buddy to watch for spark leakage after dark. The electronics under the flywheel, which I call the timing sensor and pickup (probably not the right terminology) are clean and wires are in good shape. There is evidence of potting that ran out of one or both of those two components, but it has been like this for years and this problem if failry new after a year of not using the engine (I know, kiss of death). Fuel system is good. Just flushed the tank and all lines a month ago and it runs well once started.
Any other suggestions?
