1988 100 hp mercury outboard
lakeuser
Hi i just bought this boat, when i went to see it run the owner had already started it there was some fuel leaking from carb area also there was some small leak by a hole in the lower gear case it looked dark he said he thinks he primed it too much after running the leak stopped he thought there was a leak at the lower unit said it just started that day iam wondering if it was just the fuel coming out of the lower gear case hole any thoughts ? thanks John
flyingscott
Both those issues could be normal. Unless he gives you a warranty or you can test drive it be very leary of it. If it is the 4 cyl motorThey are excellent motors but are known as 2+2 motors. They run on 2 cylinders until 1800 rpm then the other 2 kick in. So if you heard it idle you heard it run on 1/2 the motor.
jimmbo
Well the first alarm bell that go off for me is "i went to see it run the owner had already started it". When I purchase an engine, I want to see how easy it starts while cold.
The drippage from the gear case might be gas-oil. or it could be gear oil. Get some on your fingers and smell it. Gas-oil smells like, gas-oil. while gear oils can stink to high heaven. Bleach will remove the stench from you fingers
lakeuser
I did buy the boat i was thinking about letting run a bit in the driveway and see if it still leaks thanks for the replys
