Yes. Take the lower unit off. Use a pair of pliers (gently, as to not muck up the splines) and turn the shifter on the drive until you get forward. Determine this by turning the driveshaft clockwise, you will see the shaft turn clockwise as well. Then put your shift lever on your control box to forward. Install the drive and test it.
