DixieSpeed
- Jul 9, 2011
- 11
as the title says i have a '87 i4 165. i have tested everything i read about in the mercruiser needed to know section. the starter slave solenoid works, it puts 12v to the starter and it cranks, it puts power to the coil but not much. thats where i believe my problem is. the engine turns over but will not catch. it gets fuel but no spark. i've tested the coil and it gets 12v through the purple/yellow wire from the starter slave solenoid. when the coil has the grey wire and the black wire hooked up it doesn't get grounded to provide power. there was a spare wire hooked on to the valve cover bolt by the previous owner, i believe it was to hook on the alternator kit. i used it to ground the coil but then the coil only gets 3.6v to the coil from the slave solenoid. i don't know whats up with that grey wire other than i read somewhere its to the tach or hour meter. its most likely my problem but thats why i'm writing this, cause i'm no expert. thank you for any help.
