1987 MerCruiser 3.0 Flywheel size
GeauxJoeAllen
Is there a way to tell the flywheel size without removing the motor? 12 3/4" or 14"
I am going of doing an engine swap after cracking my 3.0 block. I don't want to pull the motor until I have its replacement.
Thank you in advanced!
Joe
Scott06
The 14 inch flywheel will also use a starter with staggered bolts
The 12 3/4 uses a starter with inline bolts
Yes 14” flywheel was part of move to single rear main seals. If the OPs engine is original it will have the smaller flywheel. I think 1990 (engine manufacture year) was cut over date
