1987 mercruiser 2.5 no spark issue
avanti16
Hey everyone, I seem to be having a problem getting spark on my "new to me" boat.
motor is a 1987 mercruiser 2.5. I just replaced the coil and checked all connections and cleaned every one of them, i get power going to the coil, but no spark at the plugs. could it be a problem in the cap? I also tried to see if i get power coming from the plug wire coming off the coil to the distrib. and didnt get anything while motor was cranking.
Any help is appreciated!
Thanks
-Joe
Don S
Re: 1987 mercruiser 2.5 no spark issue
Probably just another set of points that is corroded/glazed over. New points and condenser is the cure.
Up in the adults only sticky is info on the points system you should look at.
  • SM10 points ignition.pdf
avanti16
yup your right, thanks for the reply.. the points were pretty shot from corrosion. when i cleaned them they were about half gone! i looked up some pics of how long they should be.. mine points are nubs! thanks again for the help!
Don S
I may have added the .pdf document while you were posting, might want to download it.
avanti16
update: replaced the points, cap and rotor and she fired right up! thanks again for the help Don.
