Re: 1987 mercruiser 165hp 3.7
Just thinking about this, if it is your hose between the outdrive and the transom, you should not have to pull the outdrive all the way off to clear it, If you just slide it back about 1 inch that should give you enough clearance. If you backflush the water will be coming out of the hole with the O ring on the port side of the bellhousing. Should not have to replace the gasket, just make sure the O ring is back in place when you put it back together (some grease should hold it). Good luck.
