1987 Mercruiser 165 hp IO (neutral problem)
Jimshoe
I can easily shift from neutral to drive or from neutral to reverse, but when going from drive or reverse I have trouble getting the shift to neutral. I usually have to go from drive to reverse or reverse to drive before I can get to neutral. It never really feels like the shifter clicks to neutral.
Don S
Re: 1987 Mercruiser 165 hp IO (neutral problem)
With the engine running, activate the shift interrupt switch and see if the engine dies.
Jimshoe
Ignorance. I see a neutral safety switch in the manual (Same thing?). Not sure where to locate.
Jimshoe
The shift interupt switch works. I adjusted the linkage and the shifting feels right but haven't had in the water yet so not sure. Appreciate help and the link so I could learn the how's and whys of the system.
