Evinrude Boater
Thread starter- Joined
- Jul 6, 2004
- 1,148
I searched the forum but didn't find much on high oil pressure. The oil pressure gauge is electric and no numbers on the lines so I don't know how high the pressure is measuring. At idle and warm up it was reading where it always does then when I accelerated running 3k-4K rpm the oil pressure gauge was maxed out. It came back down as I slowed down. After a while I tried it again and it went higher than normal but no as high as earlier. The temperature gauge reads in the normal range and no unusual noises. Is there a risk of damage if running with this high pressure? Besides connecting a mechanical gauge is there anything that can be checked?
