j_k_bisson
- Oct 6, 2010
- 1,082
Re: 1987 Johnson J200TXCUC lost power
I chime in here. You still have all the hoses and crap for the factory 1987 water thermostat system. If you do I would remove all the hoses, water control valve and plug off every feed line. Replace them with the setup I put on mine and I rebuilt it. You just need to buy the covers new springs (tweek them to 1.75" long buy cutting them to length), gasket and new t-stats. The old system parts are not all available anymore. Plus when the old system failed the motor failed. The system I am sugesting you use is basic and the water pump lifts the stats off the seats when you get above 1500 rpm. You don't need to equalize the water pressure between each side and crap.
Just a recommendation. Also search for the rework on here. I look for it and forward you a PM with the details. I think I still have a set of covers lying around if you are interested.
