ClaytonSikes2003
Thread starter- Joined
- Feb 24, 2003
- 14
Hello all!<br /><br />I am in the process of changing out my water pump housing and impellor. I have been reading through some past posts, but I am still confused. If I am correct, I place the impellor down first then the housing, and turn the drive shaft clockwise to seat the impellor into the housing. Someone also told me that I should place a small amount of grease into the impellor housing in order to make it go in smoother. Is this correct? I am also confused as to what side of the impellor goes down onto the gearcase. The impellor looks the same on top and on bottom. The key way goes all the way through, so it can go either way.<br /><br />Thanks for any help.<br /><br />Clay
