Max_Florida
Thread starter- Joined
- Oct 4, 2011
- 6
I have a knocking sound coming from the motor and the compression on Cylinder 1 is 90psi(others are 135psi).
History(Sorry it's long, I tried to be as thorough as possible):
Before we went out yesterday I ran it on the hose - I noticed what I thought might have been a QUIET ticking noise. Not having a lot of experience with outboards I didn't know if it was normal or not, so we went out anyways.(STUPID STUPID STUPID)
Pulled away from the dock, idled out, hit the throttle and it chugged up to about 2700rpms... ran horrible and very underpowered. We stopped the boat and messed with the motor for a while, finally got it running. Limped back to the dock, the motor was running awful.
Trailer it back to the storage lot. Run it on the hose and it's shaking and running very poorly.
Take out the spark plugs(they were rusty, we were thinking the problem was ignition related) - the bottom 3 have what I think is the typical black oily "wet" residue on them. The top is dry and a light brown color(uh oh).
Compression test all 4 cylinders - top is 90psi, all of the others are ~140psi(all of the cylinders were 140psi a few months ago).
Put in new spark plugs and start it up - motor runs smooth on the hose but the knocking sound is very noticeable.
Took the plugs back out, sprayed a 1-1 ratio mix of fuel/oil into the spark plug hole on the top cylinder. Rotated the stator on the top to get the cylinder to cycle. Put the spark plug back in.
Then we took apart the top carb and made sure everything was good to go - nothing was stuck in there. Put the carb back on, but took the cover off.
Started the motor up and gently sprayed the 1-1 fuel/oil mix into the top carb as it ran. I was hoping that as I lubricated it the knocking would go away and compression would come back up. No such luck.
I am thinking that the problem was caused by(obviously) that cylinder running lean. I am planning on rebuilding the fuel pump this week.
Here is a video we made so you guys could hear the sound: http://www.youtube.com/watch?v=BnOqlBLKOmM&feature=youtu.be
I am thinking that I will need to probably at least partially rebuild the powerhead? Any advice would be greatly appreciated!
Thanks in advance!
Thanks in advance!
