1987 Evinrude Normal Compression
scott hamilton
E175TXCUA. On cold engine. Engine had not run in over 10 years. Lubricated day before and turned once by hand to distribute on cylinder walls. I got 85-90 on all 6 cylinders. Is this within specs?
Crosbyman
likely to low for now but don't worry at least they are equal… just run it for a while feed it some decarb like POWER TUNE retest compression after a few hours . some would burn a can of SEAFOAM
change the impeller BEFORE running it if not………. who knows what will happen
oldboat1
^^All good advice. I don't like to use additives or cleaners unless special cases (Just 2-cycle at 50:1 will do the lubrication job, and could always squirt a little into the cylinders before firing if desired.) As suggested, if run dry for even 30 seconds, should change out the impeller -- also think some regular running could improve compression, as mentioned.
Carbs may need cleaning and kits. I would check fuel for water or other stuff before running to avoid contaminating carbs whether you have first cleaned the carbs or not. (Another reason why I don't like adding solvents to the fuel source before running -- can loosen up and transfer nasties from tank.)
