1987 evinrude 140hp E140tlcua
eathen13
1987 140hp
1994 javelin 363b 17ft bass boat
6” jackplate set at about 3.5” ptp
19p prop new prop an hub
Compression 120/120/120/118
So I’m having a weird issue going on with my outboard and at this point I’m stumped , it’s starts and idles great , go to take off and plain out it hits a 2900-3000 rpm wall and a couple of times it has stuttered and come alive boat planed out and ran great , stopped and fished and it hits that 3000 rpm wall , squeezed primer bulb and no change , pushed in key to choke it an no change , tried 3 different prop sizes and all do same thing , started testing ignition and got DVA weird reading on one pin of timer base so ordered a new one and a stator while I’m at , replaced and set timing at 18 degrees per manual , still no change and verified link an sync timer is freely turning , I’ve ran boat on portable tank with new line and primer bulb and verified proper vent and no change , list below of what’s been replaced or tests done etc.
All fuel times tank to carbs an pulse line
Fuel pump
Carbs rebuilt
Power pack -Sierra
Stator-oem
Timer base-cdi
Plugs -ql77jc4
Water pump
Thermostats and diaphrams
Grounds cleaned
Ran with timing light each cylinder no difference
Portable tank new lines an bulb no change
Raised jackplate an no changed
Ran 15p prop 19 p prop an same
Disconnected kill switch an no change
Main jets are 59d
What am I missing why won’t it run past 3000 rpm?
  • IMG_6360.mov
saltchuckmatt
Do a spark drop test and then do a cylinder spark GAP test. 7/16 with a bright blue crack. Spark gap tester are $12 at any auto parts store.
jimmbo
With a 4 inch drop in Pitch, it still won't go above 3000rpm. Even with a dead cylinder the revs would go up, with less pitch.
I would be looking at the S.L.O.W. feature. Perhaps the temp sensor/switches are shorting, or the Wires going to them are pinched/abraded. Disconnect the Tan wires going to the Power Pack to see if that makes a difference
tphoyt
Is the motor trimmed all the way down in the photo? And are you missing the cotter pin on your prop nut?
saltchuckmatt
Tim might be on to something, hard to say it's not an optical illusion. Is this a longer shaft motor on a shorter transom? Another words, why the jack plate? But if it's to high your RPM's would go up.
To me it looks like this is NOT your problem.
