1987 Blue Fin Sportsman 1900
fritzL
Hello All
History
Free boat... go ahead laugh get it out yer system...
Would not run consistent etc. Found it to be a destroyed impeller.
Now she runs.
It comes with a 20bgall9n bow tank.
Itneas opne bow, i fitted a casting deck and chair, then added a bow mounted trolling motor...this i believe has caused trouble, it is 36 volt and i added 3x 12 v batteris, at 66 lbs each.
One day i had the boat up to 32 mph, as read on cell phone app via satelite.
It was rough shifting always so i found a new to me but used outdrive and replaced it. It came with the same pitch propeller but 1.25" larger diameter than what i had.
Now the boat wont go past 20mph and in gear no higher than 3000 rpm.
1 - Did people put bow mounted trolling motors on this model?
2 - Did i over load the boat with the batteries and deck?
3 - Is the propeller beimg larger in diameter an issue?
I did have a "whale tail" on the ild lower unit. I have it and will install today pr tomorrow after the 4th of July activities...
Thank you for reading
