1987 85 force Installing new trigger assembly
bubba46923
I have a 1987 85 force motor I need to replace the trigger assembly is it real hard to do.
Frank Acampora
Re: 1987 85 force Installing new trigger assembly
Only if you have trouble removing the flywheel. If you have a flywheel puller, you just take off the flywheel, disconnect the trigger wires, (some are plastic connectors, some are wired to a terminal board) disconnect the tower from the trigger lever (one screw but difficult to get at because the head points down) and lift out the assembly.
