mark1961
Ensign
- Apr 30, 2007
- 940
Re: 1987 50HP Johnson need some help
I dont think there really is a weak link as such.....the insulation on the motor wiring harness has a tendancy to deteriorate over time causing corrosion in the wire strands but this is probably a fairly common occurance in all oldish motors.
Will do thanks. What is the most common problem with these engines? Electrically anyways
