1987 50hp Evinrude E50TLCUD Thermostat Replacement
FishAtFive
The problem of it idling poorly after warming up has never went away and no matter what I've replaced/rebuilt the problem persists and frankly I am just done with it. This weekend I am pretty sure it got stuck closed because it lost all accelleration and the temp alarm went off. So here we go.
I'm going in, wish me luck. Will post updates here.
Honorary Supreme Mariner
Did you ever post the actual compression values on this motor?
FishAtFive
I believe so. If I recall correctly they were between 140 and 150 and +-10% of each other. I checked twice, when I first started working on it and after the last time it overheated. Disclaimer: crappy amazon tester used.
FishAtFive
All 14 bolts are turning except this middle one. I can see the head turning but springing back, which means it's not actually turning. I think I learned that from a Joe Reeves video. Got PB on it and now I wait.
FishAtFive
Got the last one out! Had it soaking in PB for about two days, plenty of light tapping with the hammer, and then I put some heat on it and came back a few hours later and it slowly came out. I'll take the head cover off tomorrow. I really hope to find the thermostat is indeed shot.
FishAtFive
Inspected the thermostat and only thing I can conclude is that it was stuck closed and the pressure relief valve must have gotten stuck closed as well or clogged, leading it to overheat. I don't know how those correlate to it going into a sort of "limp mode" before this happened. I had it full throttle and it was not ramping up, but after I let it cool down it ran ok. I thought the 1987 E50TLCUD did not have a concept of limp mode, and I don't know how the computer would even know there was a temp situation as it is not integrated with the temp sensor.
There is no limp mode on this motor.----There is no computer on this motor.
FishAtFive
They are both almost exactly the same at 160 psi. Note - the last two times I checked it was not as high. Is this bad? Should I bother ordering the parts to fix the thermostat?
FishAtFive
Ok I went ahead and ordered the parts anyway since the total wasn't that bad.
[0323359] Screw (3) $4.44
[0315538] Cylinder Head Cover Gasket (1) $6.43
[0316132] Grommet (1) $11.23
[0310058] Thermostat Housing Seal (1) $3.5
[5005440] Thermostat Assembly (1) $24.08
Shipping $4.95
Sales Tax $4.6
TOTAL $68.11
I also got a plumbers wire brush from Home Depot to clean out the recepticles, there is a lot of corrosion in there. I plan on stuffing a rag soaked in vinegar for a day to try and break some of it up before brushing it out. It's pretty hard to get to it. I guess the only way to improve access is remove the whole powerhead?
Crosbyman
to clean the innards of the water circulation cavities you could run some descaler product ... check Rid -Lyme etc... check utubes
FishAtFive
I may do that, I'm thinking it over. Just a matter of when, I want to get this back together and salvage the spring fishing season, and I also dont want to poke to hard at 40 years of buildup without doing a very thorough job. I see there is another plate I can remove on the side. Perhaps next winter I will do a thorough cleaning.
Does anyone know if the water goes into the side chamber from the thermostat port or the other port to the right of it? In otehr words, which direction does the water flow through the thermostat in this motor? I could hook some muffs up to it and see but I wont be able to do that for a few days.
FishAtFive
Tomorrows the day, putting it all back together. Can I get some help with the thermostat seal? I'm not sure what side the flange should be on. Manual is not clear. I've found pictures and videos with it both ways.
FishAtFive
Ok another question. A dumb question, but I'd rather ask a dumb question than waste a ton of time and money fixing the impeller. I wanted to flush the motor a little bit before putting it back together. When I crank the motor no water is coming out of the thermostat and relief valve holes. Does the impellor need back pressure to work? I could have sworn it was still peeing when I got back to the dock after the day it overheated.
EDIT: Nevermind - I was just being impatient. I needed to let it crank for about 5 - 8 seconds before it shot out. Phew.
MarineSp
The seal flange goes toward the thermostat housing (facing outward/away from the block). The flat side seats against the thermostat itself. Think of it as the flange creating a lip that the housing presses down onto to make the seal.
Also regarding your earlier question about water flow direction — on the E50TLCUD the water flows up from the impeller through the powerhead, past the cylinders, and OUT through the thermostat. So the thermostat is on the outlet side. When its closed the water recirculates inside the head to warm up faster, when it opens the hot water exits and gets replaced by cool water from the impeller.
160 psi on both cylinders is actually fine by the way. These 2-cylinder crossflows are spec'd around 150-170 psi and within 10% of eachother is good. The fact that they went UP from your earlier reading of 140-150 probaly just means your amazon tester is inconsistant, or the engine was warmer when you tested this time. I wouldn't worry about it, the thermostat fix was the right call.
