swfl_fishin
Thread starter- Joined
- Oct 7, 2008
- 20
Okay. Been working all day trying to figure this out. Here's my situation:
I have (2) batteries with a Perko (OFF-1-ALL-2) switch. The first battery is a starting battery and the second is a deep cycle.
Problem: The voltage reading of either battery is 11.88v even when the motor is running. The motor will start with the switch in the 1 or the ALL position. It will not start with the switch in the 2 position.
I disconnected the rectifier wires and used the ohmmeter to verify that current is only flowing one way.
I also measured the coils of the stator. They may be out of spec slightly, but don't know if it is enough to make it fail. The specs say between 0.22 & 0.32 on the R x 1 scale. Problem is that my multimeter only has a 200 ohm scale. On that scale, my reading was 00.6.
Any ideas here? Shouldn't the voltage be ~13v when the motor is running? Should I replace the stator? Replace the batteries?
Any help would be greatly appreciated.
