FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
1987 omc 3.0. The front engine mount, where it bolts to the block has a shim on each side of the mount. My question is Crowley marine says it takes two shims on the starboard side does anyone know why it needs two and not one??
Well, I can't tell you why they use them, but if they call for 2 of item number 4 (Not #6) I would sure use them. If you don't the mount will not set square to the block. They are also called backup plates, not shims. What the difference is, I don't know. But between 86 and 90 they (OMC) used them, so if it was mine, I would too.
Thanks a million Don!! Sorry i meant 4 not 6. I have them ordered I plan on putting them on, i have found so many things not put on correctly, i always check everthing out good to make sure its right when i install an engine or drive.
