1987 20 hp mercury timing adjustment
yzchamp
i have a 1987 20hp merc that i converted from remonte to tiller . in the process i changed all of the linkages and timing got all screwed up. all of the dots and lines on the fly wheel are are quite confusing .. what dot/ line on the fly wheel do you use for a reference for at idle? dos any one have a manual for it?
yzchamp
Re: 1987 20 hp mercury timing adjustment
any one has an idea ? or a picture from a manual where the timing should be at?
windy5849
View attachment 107675Here is the timing marks for a 1990 25hp motor.I don't know if it is the same for your 20hp.but I would think so.Hope this helps.
yzchamp
invalid attachment.....:(
yzchamp
that's awesome ! thank you sir! would u mind posting carb adj part as well?
windy5849
Do you have the "BC" or "WMC" carb?The adjustment is different for each.
windy5849
