1986 ss 201
Status
Not open for further replies.
PlayD0h
Re: 1986 ss 201
Looks awesome Glen, and nice catch.
This place is always good for a few laughs from the peanut gallery.
dozerII
Re: 1986 ss 201
I was going to suggest the same thing as Jim. Then I thought, nah, Dozer's been to the rodeo before.
No doubt about that! Sometimes it is the simple things the best of us over look!!!
Ya guys I been bucked off on my head a few times ( might be the problem)
J.
Thanks Paul, never a dull moment, what did you decide on your outboard dilemma?
I hate not knowing what's going on with my motor.:frusty: So I did another compression test all 6 are the same just low compared to what the manual says, now I think the motor only has about 3 hours on it total (but can't confirm that with the P/O) if it is new that would explain the lower #s not broke in yet. I know all the fuel filters are new I put them in and the tank is clean as a whistle cus I emptied it and clean it. It has 30 gal of fresh Premium gas in it with a can of Seafoam. I pulled the plugs like I was told in the Mercruiser forum to see what they looked like, now they only have an hour tops on them so not a lot of time to get color so to speak, but they look like they just came out of the box.
That tells me not enough fuel, but I can firewall the throttle from a dead start and there is not a second hesitation or burble till I hit 4200 rpm and there it dies?
Go figure????
barato2
Re: 1986 ss 201
that doesn't eliminate fuel issues and that's where i'd continue looking. on cars, the first place you'll notice fuel supply issues is not during full throttle acceleration, it's sustained hard running in top gear....like over time, the fuel system can't keep up with engine's demands. the fuel for immediate acceleration like you're describing comes from the reserve in the float bowl, which is why they have float bowls. what happens once the float bowl empties if the supply can't keep up with the demand is the problem.
OTOH, i'd expct fuel supply issues would show up as a lean condition and your plugs do look perfect.
the other Q is spark advance, which might explain what you're seeing. that's cheap to check. mark your distrib position, then loosen clamp while on the water and play with advancing and retarding things a tiny bit to see if it improves
dozerII
Re: 1986 ss 201
Thanks Bruce, I'm going to try to get out Saturday, with the timing light again, but I'm thinking the problem is the carb, I would really like to see plugs on the black side over the clean or white. Even with gas $5.48 a US gal.
SigSaurP229
Re: 1986 ss 201
Hey glenn
I am sorry to through this one out there buddy, I think your motor is shot man, its ok you can send the big ole girl down here for proper disposal.
Not that I have anything really usefull to add as I am an outboard only kind of guy, but there isn't a throttle stop screw inside of the throttle box is there?
Gibbles
Re: 1986 ss 201
It's godda be your crazy health care related taxes eh, but it looks like we are joining the club...
then again us americans have less threats of polar bear invasions to worry aboot there.
PlayD0h
Re: 1986 ss 201
Premium Fuel = Premium price :)
I think I'll likely stick with my motor, mainly financial reasons.
I just overhauled my carbs, all new gaskets, ect. Get out to the lake and boat started fine, idled out of the marina fine, hit the throttle and Blah. 10 mph tops. I know the feeling of obsessed with the problem. I had to tear in to it the next morning, and found I switched top carb with bottom carb. Do'h :facepalm:
Gibbles
Re: 1986 ss 201
hopefully the speed problem is that simple, but still 38mph is not all that bad... Compression test had been done, eh? I have the 4.3 in my tow rig... sure the ign is good, eh? Honestly I'm not sure aboot the differences with the thunderbolt ign compaired to my chevy ign, but I could raddle off all sorts of reasons powre could not be all there... if a dist system pull off the dist cap and make sure all the screws are there in the rotour, I had one work it's way oot and gave me a top speed of aboot 55mph this one time, ran/idled fine but the rotour was wild and free!! in that same area a big one there would be the timing advance depending on the setup on the s10 there are two thermo sensors, one four the gauge, and the othre four the computre, but that's assuming it's fuel injection... also a general blockage in the exaust...
(I'm working on my canadian there eh :lol: :behindsofa:)
dozerII
Re: 1986 ss 201
Hey glenn
Hey Sig, Ya you might have to come get her;) Throttles opening all the way, I checked that last weekend.
It's not sounding good for gas prices for the rest of the summer, maybe $6.00 a gal for Premium. Glad you figured out your problem easy, I hate it when a guy doe's the DOH thing.
Depends on which state you live in Chris, Alaskans see Polar bear way more than us.:D
(I'm working on my canadian there eh :lol: :)
Couple more trips up here and you will have the EH down as good as Jason:laugh:
Compression is good, checked distributor the other day, not much in there all advance curve is done through the Thunderbolt module. Hoping to get out on the lake this weekend to do some more testing on the fuel system. The carb is my main suspect, it was in terrible shape when I brought the SS home. I rebuilt it but it still has a lot of rust on the butterflys and steel components.
barato2
Re: 1986 ss 201
any possibility a butterfly is binding? ifd you don't come up with anything more obvious, maybe pull the carb apart again and burnish all crusty bits with red scotchbrite? gun cleaning kits work well for cleaning throttle shaft etc bores but i usually avoid the brass brush to keep from gouging aluminum of carb casting.
if all else fails, it's clearly time to 86 the carb and buy this Holley TBI i have sitting in the garage. a Megasquirt to control it, a few sensors, and you be rockin.
dozerII
Re: 1986 ss 201
Thanks for the offer Bruce, I just ordered a new carb off Fleabay for it, don't want to chance burning her up.
dozerII
Re: 1986 ss 201
Carb arrived and is installed, I also ordered a fuel pump just in case. It will not quit raining here long enough for the mud to dry up, and when we do get a break in the rain the wind blows at 30 to 50 mph. Here's hoping this week improves.
dozerII
Re: 1986 ss 201
Got done early today and took her out to the lake for a test hop:frusty: The lake was the nicest I've seen it since the photo shoot for the Naked Lady, not a ripple on the water, 25C 70F boat runs like a piece of @$@#$, got a gas leak at the carb filter smoking black and it doesn't seem to want to adjust, oh well back to the drawing board.:mad:
SigSaurP229
Re: 1986 ss 201
Hey Glen,
Sorry to hear about the luck man, at least you have plenty of others to run until you figure out whats going on with her. Get some fishing done then go back to the drawing board. :)
jasoutside
Re: 1986 ss 201
Shoot man, shoot!
I know you'll get it figured buddy, I have full faith.
classiccat
"Captain" + Starmada Splash Of The Year 2020
Re: 1986 ss 201
That stinks Glen! Hopefully a simple solution for a simple problem and you're back on the water ASAP!
catfishr1
Re: 1986 ss 201
Sure sorry you are having problems with your engine Glen. Know you will get er figured out, sure hope it will not cost too much more. I feel for you my friend.:sorry:
dozerII
Re: 1986 ss 201
Hey Glen,
No others to run sold the 72 to my BIL
Shoot man, shoot!
Hope the wind stays away to day so I can go a t it again.
InMotion
Re: 1986 ss 201
Mmmmmmm...... not good there.... Sorry to here that bud. No doubt you will get it resolved though.
J.
pckeen
Re: 1986 ss 201
Read this from start to finish - remarkable work, and very educational.
Status
