1986 Mercruiser 3.7 170hp
southwest395
[FONT=&quot]I have a few question if anyone can help ? I have a 1986 mercruiser 3.7 170 closed coolant system. I bought the after market 3 wire conversion kit. I broke to of the tabs that are water pump/timing cover. I got a new one to put on. Do i need to buy the gasket for the two parts or can i use rtv ? other question is i had to move the pulley and the stator coil to get to the last bolt. Can i brake the magnets of the pulley or leave them on? also to i have to put the stator back it ? Now to remove this pulley i had to get a puller for it. How do i go about putting back on ? it says not to hit wit objects.[/FONT]
Capt. Click
I would buy a gasket kit for the timing cover and pump housing. I have converted my 3.7 to the alternator. I took the magnets out if my Balancer, no need to put the stater back on either. To get the balancer back on I took the original bolt to a hardware store and got one longer and thread it on with the longer bolt with washers. I put one continuous hose from the raw water connection to the HX. I removed the voltage regulator also.
Personally I would use the gasket
I left mine on they were secure and didn't feel the need to remove them. The stator is no longer needed, you can leave it off, sell it on ebay.
With a harmonic balancer installer:
