1986 merc 115
dggreener
I have a 1986 Merc 115 6 cyl. It is running very rough and checking at an idle it looks like I have no spark in #1, #3, and #5. Could this be a stator problem? #1 and #3 use the same switchbox but not #5, I am puzzled.
jimmbo
Re: 1986 merc 115
1, 3, and 5 use one switchbox, 2,4, and 6 use the other. Perhaps some wires got mixed up. As for the lack of spark... most likely a switchbox is the culprit, with a lesser chance of the trigger being the demon.
dggreener
Re: 1986 merc 115
Thanks, I did some research tonite and I think you are right. I switched over the leads from the switch boxes and determined it is the upper switch box. I did'nt realise that the switch boxes were 1,3,5 and 2,4,6.
redjmp
Re: 1986 merc 115
My 86 115 has 1,2,3 on the top box and 4,5,6 on the bottom.
Don't know if it came that way or if I just rewired it that way after rebulding...
