1986 Johnson 70 HP won't turn off
lodge
I just got a boat, basically for free. I knew a rebulid was on the radar and have reciently sent it to be rebulit. I was testing it out, and I got it started, but it wouldn't turn off when I turned off the key. The dead man release also wouldn't shut it off. Any suggestions ?:/.
tashasdaddy
Re: 1986 Johnson 70 HP won't turn off
yellow black wire is kill wire, make sure it's connected. you can allways choke it.
lodge
When the key turns turns on you get 12V + yes no?
when the key turns off does it ground out?
You are talking about the wires on the starter solonoid yes?
Thanks
rickdb1boat
Black/yellow Wire is from the ignition to the powerpack. Grounds out when key is turned off and kills the engine...
