TownsendsFJR1300
- Nov 3, 2013
- 15
Re: 1986 johnson 110hp still won't start
I did notice that there is some fuel spraying out of the top of the solenoid where the red knob meets the body of the solenoid. QUOTE]
I'm not familiar with this, maybe someone can chime in re that fuel spraying.
Something not noted (or I missed it), have the carbs ever been cleaned or at least gone thru?
Besides the age of the engine, with the crappy ethonol fuel, if it was stored without draining the bowls, the main and idle jets are likely clogged (they have really, really small orifices). Either Non ethonol fuel or a good fuel stabilizer is ABSOLUTLY necessary nowadays as regular fuel can go bad in as quickly as a month..
You mentioned your engine sputtered a little bit when choked, which makes sense. The engine is getting some fuel (not utilizing the jets) but not enough to run on the jets after that. Simply checking the plugs after cranking over to see if their WET with fuel will let you know IF the engine is GETTING FUEL. The one plug, nice and clean also suggests the cylinder isn't firing, very likely because it isn't getting fuel to burn (and thus leave deposites on the spark plug)
IMHO, the fuel system is by far the weakest link, especially here. To check/clean the carbs is petty simple. Once the carbs are off, simply remove the bowl(s). Access to the jets should be right there. Yellow varnish on the inside of the bowl is a sure tip off as well that the jets are clogged..
Don't just look at the jets, pull them and make sure you can see light all the way thru the jet. As small as some of the jets are, should you need to poke a piece of wire to dislodge any crap (carb cleaner, air compressor doesn't work), a cut off piece of wire from a WIRE BRUSH, clamped in a small vise grip should fit thru.
