1986 HL-180 (holiday) - do I buy?
klennski
Local facebook ad for a 1986 18 ft Holiday aluminum boat(closed bow). Was just repowered with a 1998 Yamaha 115 which looks to be in good order, video of it running.
Wondering if this year/make of Starcraft had any issues or anything I should be looking for when I check it out. Or if I should steer clear. It was painted army green and apparently was used for duck hunting in salt ponds in Rhode Island most recently. Was told the floor is solid. I'd be trailering it for light salt water use in the bay on calmer days to just kick around inshore and no-frills learn how to boat. I'd be repainting it at the least before the season. Should I just look for a small fiberglass boat instead?
Verapierce
Based on the information you provided, it sounds like the 1986 18 ft Holiday aluminum boat with a 1998 Yamaha 115 could be a good option for light salt water use in the bay. However, there are a few things to consider before making a decision:
Research the boat's history: Since the boat has been used for duck hunting in salt ponds, it's important to know how it was maintained and if it was regularly cleaned and rinsed after each use. Saltwater can cause corrosion and other issues if not properly addressed. Additionally, find out if the boat has been in any accidents or had any major repairs in the past.
Inspect the boat thoroughly: When you check out the boat, take a careful look at the hull, transom, and other areas to make sure there are no cracks, holes, or other signs of damage. Check the steering and controls to make sure they are functioning properly. Also, inspect the engine and propeller to ensure they are in good condition.
Consider the age of the boat: The 1986 Holiday aluminum boat is nearly 40 years old, so it's important to keep in mind that older boats may require more maintenance and repairs over time. However, if the boat has been well-maintained and has had recent upgrades like the new engine, it could still be a good option.
Think about your boating needs: If you're looking for a no-frills boat to learn how to boat and kick around inshore, the 18 ft aluminum boat could be a good fit. However, if you're looking for a boat with more features and amenities, a small fiberglass boat could be a better option.
Ultimately, it's up to you to decide if the 1986 18 ft Holiday aluminum boat is the right choice for your boating needs. Make sure to do your research and thoroughly inspect the boat before making a decision.
