1986 Evinrude 70 hp tach not reading correctly
finish line 88
Just purchased this motor and the tach moves but it nevers goes over 2500 rpm.
Not sure what to check next. Rectifier test OK but only getting 8.5 volts on purple wire to tach. Can I get 12 volts from a hot wire from the battery? Any help would be great
Bob_VT
Re: 1986 Evinrude 70 hp tach not reading correctly
First thing to check is the Pole setting on the tach. It should be set at the 6 postion
finish line 88
The tach is an older OMC model and there is not any adjustments on it.
finish line 88
Will the low voltage affect the tach?
boobie
Try running a jumper wire to the tach and see what happens.
finish line 88
Tryed running 12 volt to tach and still does not work
boobie
If your charging system is okay, it might be time for a new tach.
