Just bought this bought and having a problem with a skip in the engine. Starts OK but when idling there is a definite skip through the exhaust.
Also, out on the water it will not run at full throttle, seems like it's pulsating and not getting enough fuel.
Has a new tank, primer bulb, gas lines, I cleaned the tank out, checked the screen and everything looks good.
Wondering if the carbs need cleaning or is it a compression/top end problem.
