1986 Evinrude 40HP
NH Pete
Just bought this bought and having a problem with a skip in the engine. Starts OK but when idling there is a definite skip through the exhaust.
Also, out on the water it will not run at full throttle, seems like it's pulsating and not getting enough fuel.
Has a new tank, primer bulb, gas lines, I cleaned the tank out, checked the screen and everything looks good.
Wondering if the carbs need cleaning or is it a compression/top end problem.
The # 1 test to do is compression.----Then check to see if there is good spark on both leads.--------Good spark is spark that jumps a gap of 3/8" or more.
NH Pete
Thank you, does anyone know what the compression should be.
Thank you
boobie
Do a cylinder drop test on it when your running it on the water to see if you have a dead cylinder.
bonz_d
I have 3 OMC 2 cylinder here, 2 50hp and a 60hp. They are all running between 140 - 150 with the gage I have.
