1986 crestliner
Arronh
Hi. Can someone help me find the model of this crestliner hull? NOR11019j586
thanks
jbcurt00
Its a 1986 Crestliner
Success! NOR11019J586 is of the standard HIN type called Current-Format HIN. If you are buying this boat/craft then you should get the Boat-Alert History for 19.99$ from the two certified boat history report providers. NOR HIN Decoder
Our HULL ID Decoder breaks down the Hull identification number into the following information:
The HIN or CIN you have entered meets the Current-Format HIN format. It might also be a type that contains the country code and thus the boat comes from USA or Other . The serial number of the HIN is 11019 and is set by the boat builder. This boat or vessel has a Certification Date of (5) and a Model Year of 1986 with month of build (October) based on the formatting of your hull_identification_number (HIN) .
The manufacturer identification code (MIC) of your craft identification number (CIN or HIN) is NOR. This MIC (NOR) stands for the company name Crestliner Inc which is currently Out of Business. This boat manufacturer has other company names (NOR sometimes goes by these name(s) Crestliner Boat Co, Nordic Boat Co Inc, , or ).
This company (Crestliner Inc) is owned by Charlie Nelson and is located at 609 13th Ave Ne in Little Falls state of Mn. It manufactured this vessel and placed your HIN or CIN on the hull. The Parent Company for this boat maker is GENMAR HOLDINGS INC()Crestliner Inc has started making boats, yachts and other watercraft as of 4/6/1981 and went out of business on (4/6/2006) in the following country: USA. The Model Name is uncertain for this Crestliner Inc. But we have approximations: NORDIC or ENSIGN 16.
Contribute a better one to the database please:
Make sure to compare the date of boat manufacturing with the dates in which the company was actually in business.
The US Coast guard provides this comment about this watercraft manufacturer: Manufacturing Aluminum Outboards10/13/88 Address Was 1501 Crestview Dr. See New Address Abv Mso St Louis Has Assigned Nordic To Msd St Paul Mn. Formerly (crl). 000110 Crestliner Jon And Bass Boats Are Built By Nova Boats Using (gmb) Mic. 030313 Nova Oob; Crestliner Jon Boats Built By Lowe Using (glc). 03/19/03 All Low Lund And Crestliner Jon Boats Built By Crestliner At The Crl Plant Will Be Using The Crl Mic. 4/6/2006 Oob Per Ppg.
UsedHINNOR11019J586
IsValidYes - Integrity Check Passed
HINTypeCurrent
SerialNo11019
Year1986
IsStateIssuedNo
CompanyCrestliner Inc
CompanyStatusOut of Business
CompanyAddressLittle Falls Mn 609 13th Ave Ne
WebsiteWww.crestliner.com#http://www.crestliner.com#
More details at the US Coast Guard.
If you are purchasing this boat/hull then get the Boat History here. Finally, get it insured and make sure it does not have over-priced insurance by getting Multiple Quotes for Boat Insurance. There are 4 boat Recalls for your Crestliner Inc vessel:
Crestliner Inc Boat Recalls for your HIN and MIC: 4.
1-crestliner Inc Has Recalled (hin Or Cin) Due To Level Flotation And And This Boat Recall Is Closed. It Applied To 448 Boats From The 00-01 1600 Fish Hawk Side Console Model Boats. The Boat Recalls Applied On 07/08/2009 And Was Closed On With The Following Comment: Hins Affected: Nor67787a000 - Nor77061f101. 11/17/09 Cur1 Rcvd, 381 Of 448 Repaired. 02/05/10 Cur2 381/448. 06/10/10 Cur3 381/448. 08/15/10 Cur4: 381 Repaired. 12/22/2010 Cur5 - 381 Units Repaired. 04/0711 Cur6 - 381 Repaired. 052312 Plc - Cur7, 380 Uc; Cur8, 380 Uc; Cur9, 380 Uc. Campaign Closed.
2-crestliner Inc Has Recalled Nor (hin Or Cin) Due To Fuel Tank Brackets Cause And Leaks In Tank And This Boat Recall Is Closed. It Applied To 1220 Boats From The 2001-02 Sportfish 1850 Superhawk 1800 Model Boats. The Boat Recalls Applied On 08/11/2002 And Was Closed On With The Following Comment: Models Involved: 2001-2002 Sportfish 1850 I/o And Ob; 2001-2002 Superhawk 1800 I/o And Ob; And 2002 Eagle 2300 I/o And Ob. The Fuel Tank Brackets Can Cause Holes In The Fuel Tank When The Fuel Tank Is Intially Filled And Expands. This Results In Leaking Fuel And A Possibility Of Fire Or Explosion. Number Of Units. Sportfish 758, Superhawk 447, Eagle 15. 01/06/03 Defect /noncompliance Report Recvd. 1217 Units 120 Corrected. Cur#1 Recvd 192 Units Corrected. 06/02/03 Cur #2 541 Boats Corrected 888 First Purchasers Notified. 08/30/03 709 Units Corrected. 02/29/04 Cur #5 810 Units Corrected - 070525-rab-closed Case Mic Oob 060426
3-crestliner Inc Has Recalled (hin Or Cin) Due To Steering; Teleflex Helm And Binding Clutch Rollers And This Boat Recall Is Closed. It Applied To 36 Boats From The 1993 Model Boats. The Boat Recalls Applied On 20/07/1993 And Was Closed On 22/02/1995 With The Following Comment: See 930134t Thru 930138t. Forms Sent To Law Firm 930726. Dnr Rec'd 930827. Cur 1 Rec'd 931206. Cur 2 Rec'd 940201. Cur 3 Rec'd 940505. Cur 4 Received 940726. 940823 Sent Additional Curs (5-9). Cur 5 Rec 941101. Cur 6 Recd 950201; Closed Campaign.
4-crestliner Inc Has Recalled Nor......... (hin Or Cin) Due To Fuel Fill Fitting Cracks And Fuel Fill Fitting Cracks And This Boat Recall Is Closed. It Applied To 31 Boats From The 1995 Kodiak 18cc Model Boats. The Boat Recalls Applied On 13/09/1995 And Was Closed On 20/11/1996 With The Following Comment: Dnr Recd 951031. Cur #1 Recd 960130. 960520 Cur 2 Rcvd. 960812 Cur 3 Rcvd. 961107 Sent Additional Curs. 961114 Cur 4 Rcvd.
W the year and a length, you should be able to figure out the model
http://boatspecs.iboats.com/Crestlin...6/bp/54br1130y
dude, what is with the multiple threads?
