lonewolfed
- Oct 21, 2009
- 17
Re: 1986 Chaparral 235 XLC Restore
That is going to be a sweet boat. The transom can and should be made with two solid pieces of plywood with a sandwiched layer of fiberglassed epoxy in between. Use a nice piece of heavy weight cloth fiber in between.
Since you are re-doing the motor mounts at the same time distance to the outdrive should not mater because moving the motor an inch forward or back is no biggie. My concern would be the thickness of the outdrive mounting system. The sandwich transom method makes the transom at least 3x stronger than what was in there.
I recommend "Runabout Restoration" as a good book for basics (Google it-15 bucks)-it tells you how to do the transom in detail.
