stanleydan
Thread starter- Joined
- Aug 11, 2011
- 49
Hi Guy's Great forum!
Here is the start of my restore, I am still in the process of cutting and removing the floor, motor mounts and the stringers.
My first question is the transome, Since I am doing the rest of the boat I want to make sure I cover it all. I want to remove the wood and rebuild the transome. My transome measures 2" including fiberglass. It looks like 2 layers of plywood.
Here is my question, Once I cut around the transome and reveal the plywood , will this come out somewhat easily? My fear is that the wood is bonded and I would be left with a very uneven surface to mount the fresh plywood to. The 2" is measured from the back of the transome. From the pictures I have seen it looks like the plywood should pull out and make a good clean surface. What should I expect?
What is the ideal plywood to use to rebuild the new stringers / floor ?
Thanks
Thanks
