1986 AQ131/275 Drive shaft question.
I B Dead Eye
1986 AQ131/275 Drive shaft question. I replaced my u joints and seals. While making the repairs I wiggled the Drive Shaft. This is the shaft from flywheel to u/ joint fork. My question is how much play is in this shaft? Looking at parts breakdown I see a bearing. I'm wondering if mine is worn out. Can this shaft be pulled out? If I need to replace bearings and seals. Thanks for any help. Bob
I B Dead Eye
Re: 1986 AQ131/275 Drive shaft question.
Thanks Captmello, good info. I'm hoping this can all be done while still on the boat. Can you confirm this? Thanks again. Bob
I B Dead Eye
1986 AQ131/275 Spindle#69 and Ball bearing #71 removal question. I made snap ring pliers and removed the 2 large snap rings and the small one. I can move Spindle and Ball Bearing in and out about a 1/4" but that is all. Any suggestions on how to pull these parts out. I don't want to damage anything.
captmello
It sounds like you've got all the clips out. You now need to simply pull the shaft straight out using something like a vice grip/slide hammer...but also being careful not to damage the splines on the shaft. You'll need to be creative...Sorry I have not done this myself, I've got the two bearing setup and had to pull my motor.
Again, don't damage the splines!
Don S
That 1/4" movement sounds a lot like the flex plate falling apart. Can you also turn the shaft CCW and CW any?
I B Dead Eye
@ Don, No movement CCW or CW. @ Captmello I will try your idea with a slide hammer. I don't understand why they didn't Tap the end of the shaft. Sure would make things easier.
I B Dead Eye
Well The shaft and bearing are out. I welded a slide hammer to a set of vice grips and tap tap tap everything came out. No damage to splines either. Thanks for all the help.
