1986 9.9 merc 2 stroke
keith metcalfe
motor was running ok at slow speed, opened up throttle to 3/4 and traveled about1/2 a mile turned around and got back on the throtle to about 3/4 again . All of a sudden it made a loud funny noise seemed to slow down even though throttle was still at 3/4. I backed of the throttle off instantly and boat continued to move forward in slow speed but every time i got back on the throttly it made that crazy noise again so left motor in slow and got back home ok. Once home i put engin in neutral and reved it up and it seemed ok, any ideas
Rubixone
Re: 1986 9.9 merc 2 stroke
check your prop see if you didnt spin the hub, might need to have prop re hubbed, fyi its a bad idea to run you motor at high RPM when it is not under a load, thats a good way to blow a motor.
Wingedwheel
When it slowed down from the noise, did the engine rev up?
