1986/83 evinrude 90 v4 issue
Travis2329
Ok so here is what i have, it is a 1986 E90mlcdc outboard with a 1983 e90mlcte powerhead. Was put together prior to me owning it and i would have never noticed if it wasnt for the silver freeze plug on the block.
I have done a compression test and everything came back good. All ignition components are new except the timer base (new stator, power packs, coils and plugs) . New fuel line from tank to motor as well as a new pickup tube and anti-siphon valve. Carbs were rebuilt last month. Rebuilt fuel pump. New prop (same pitch as last one) and new lower unit oil. I have hose clamps on all fuel line connections. The vro pump has been removed and i premix fuel 50:1.
Heres my issue, when i take the boat out it runs great from 0-4000 rpm. If it gets higher than 4000 rpm it will run good for about 20 seconds and then bog down, but wont die just surges up and down in rpm but if i back off to 4000 rpm it will catch itself and run good all day long but only at 4000 or lower....
Im thinking its a fuel related issue since everything else is new but i cant even think of where... maybe carb float needle is sticking and starving for gas?
Also i ran it without the cowling to see if exhaust fumes were collecting under the cowl and starving the engine of air but i had the same issue...
Any help is appreciated... im so lost...
Bosunsmate
Yes id suspect fuel with that too, Have you tried priming the fuel bulb to act as a manual fuel pump at 4000 and seeing if that alleviates the problem?
Although you have got a rebuilt fuel pump things can go wrong in that system.
You will also want to check that no wires from the flywheel necklace are worn, as sometimes when the throttle is pushed down the timing base turns as per normal but the wires chaff on the powerhead over time and can cause problems
Travis2329
Yes if i squeeze the primer bulb it does alleviate the issue but, i cant seem to narrow down the issue as to what would cause that to happen
ondarvr
There are only two things, an air leak or a failing fuel pump.
Travis2329
I just thought of something, when i rebuilt the carbs, i noticed there was no clip on the float needle valve but the new kit had one in it, i never installed it because when i took it apart there wasnt one, both old and new needles have the rubber tip?
interalian
You need the clip to prevent the rubber tip (Viton) from sticking in the seat. The clip lets the weight of the float pull the tip out in the event it does stick.
Travis2329
Okay I took the carburetors apart and noticed that the one carburetor the needle valve was sticking a little so I reinstalled the clips that hold the needle valve in place. I guess I never put them in because the old needle valves didn't have it. Hopefully this fixes my problem will keep you posted. Makes me wonder if the old needle valves actually had a rubber tip where these new ones is a different material?
Travis2329
Also with the new kit there were these little white cups any idea what those go to?
interalian
Carb kits cover a range of years and may include parts/gaskets that aren't on your carb. If your carb had the part, use the new one. If it didn't, just toss the part.
Travis2329
Ok so heres an update, took the boat out today and im having the same issue... everything on the fuel system is new and everything on the ignition system (except timer base) is new. It almost seems like the fuel pump cant keep up with the engines draw at WOT. It runs good at WOT for about 20 seconds then bogs down, but then i back off to 3500 and it catches itself. I can then accelerate to 4000 rpm and it wont bog but higher than that and it bogs out... im lost
ondarvr
Back to a failing fuel pump or air leak. This is because you said it ran correctly when you squeezed the bulb.
Travis2329
So i took the fuel pump apart again to look closer. It looks like the little metal valves/reeds arent sitting flush with the plastic housing they are slightly elevated on the very front of the reed, would this small gap cause the pump to not supply enough fuel?
Bosunsmate
If using your primer ball remedies the issue then it will be your fuel pump or you dont have enough crankcase vacuum/compression to operate the pump.
Not usre on reeds without seeing a picture at least
