1986 6hp. Evenrude E6SLCDE
GasCan II
Guy's does this motor have a tell tale ( pisser ) to tell if the water pump is working ?
Thanks
Vic.S
Yes . there should be an outlet nipple located in the rear starboard side corner of the lower cover linked by a small hose to a small elbow fitting near the top of the outer exhaust manifold cover
#29 in this diag
convert
#20 and #37 in this diagram
convert
You can see it all and the pee stream in these pictures of an '84 model
