1986 50 hp force no acceleration
sadie7492
Engine starts and idles well. However when I throttle the engine up, its dies. I have cleaned the carb, replaced fuel lines, made sure bulb stays hard but still will not accelerate in netral or indrive. But when I cover air intake into carb 3/4 or with choke the engine will accelerate just fine. To much air not enough fuel thats all i have come up with, just now how to fix it?!?
Thank You!
1986 50 hp force
jerryjerry05
Re: 1986 50 hp force no acceleration
Do a compression/spark test. Then rebuild the fuel pump.J
sadie7492
ok did compression test 120+ on both cylinders. good spark on both also. waiting for parts to rebuild fuel pump. I took it apart though and small pieces were fraying off fuel pump diaphram.Parts should be in tomorrow.thank you for your reply
sadie7492
ok fuel pump stuff came in, and installed no luck still having the same problem.
steveclv
Well you have a weak mixture so maybe an air leak in the fuel lines or maybe those frayed pieces from the fuel pump have clogged up a jet in the carb.
What are the settings for the idle mixture screws? Mine run best at 1 1/8" turns out from lightly seated.
Disconnect the fuel line at the pump inlet pipe and drop it into a container - pump the primer bulb quickly and you should get a good steady flow of fuel. That means the problem is in the engine from the fuel pump to the carbs. Just work through one thing at a time.
By the way, you have seen the reason why we suggest installing a filter between the fuel pump and carbs - to catch the pieces from the deteriorating fuel pump diaphragm :)
sadie7492
ok well I fixed it. Turns out the jets were in the wrong places. The smaller jet wasnt letting fuel in fast enough. Switched them and runs like a champ. Must have been mixed up after cleaning the carb. Thanks
