wvmedic
Thread starter- Joined
- Jun 3, 2008
- 545
I have a 1986 50 hp. 3 cyl. Mercury was checking the compression and all three cylinders were at 140 psi. Is this good compression for this particular motor? I know for a car or a motorcycle it would be on the topside of good. But for boats I?m on foreign ground.
Also while checking the compression I checked for spark, shows good on all three cylinders. Fuel filter is good and clean. So hopefully when my lower unit gets here, should be tomorrow the motor should fire right up correct?
I added the other stuff so if I have over looked any thin someone might give me a heads up?
Thanks Jeff.
Thanks Jeff.
