1986 48hp johnson
Cracked above gear assembly was thinking it could be repaired.the crack is in the exhaust channel. How can I repair it
Post picture of the damage.--Hit something really hard at full throttle ?-------Was gearcase full of water and it froze ?----Failure when running at full throttle?-----Gears broken ?----Post all the information you can.
It did fill with water. No the gear case doesn't have any water inside.
