1986 35HP Merc Charing???
Bhstream
Hi I have an electric start 86 Merc 35HP. This engine does not appear to have a stator. Does anyone know if and how this engine charges the battery?
Thanks
steelespike
Re: 1986 35HP Merc Charing???
My book is a little vague but indicates there is a ign.stator and an altinater.
If you measure the voltage at the battery about 14 volts above 1,000 rpm.
indicates charging.
Laddies
Banned
All electric start 35Hp engines in 86 came with a small alternator under the flywheel you should see 2 yellow wire coming from under the flywheel to the rectifier if you are not putting out voltage as SS says ck the rectifier
