cfauvel
Thread starter- Joined
- Aug 16, 2005
- 645
referring to thread http://forums.iboats.com/forum/engin...-115hp-1996-v4
6 years ago I bought my CDI Regulator and discussed in brief the warning about running AGM batteries...
That regulator is starting to act weird...sometimes read 12 volts (battery voltage), then shoot up to 16+ volts.
the following are some questions and responses from the other thread, but starting anew in this thread.
Cfauvel
FED -
cfauvel -
Cfauvel -
FED -
cfauvel
FED -
cfauvel -
So that's where we are...need to follow the volts from the motor to purple wire to see where the voltage drop is occurring.
May start a new thread as to the BEST non-maintenance-free flooded battery
Cfauvel
resurrecting this from the dead...
didn't realize I've had my AGM starting battery for 6 years. Ditto for the REG....seems my reg MIGHT be acting up or the battery is acting up....Sometimes the reg doesn't give me juice out of the blue, then spike up to 16v+.. over the course of 6 years the non-maintenance-free flooded battery wouldn't stay charged so a few years ago bought an dual purpose AGM...
these AGMs are the bomb.
My new REG (not installed yet) of course had the DO NOT USE AGM batteries or WARRANTY VOIDED..
so started looking at non-maintenance-free batteries again...before putting my new reg in.
anyone come up with the BEST flooded batteries.
FED -
I'd question CDI before spending a penny.
OMC recommend the use of maintenance free batteries.
AGM are still lead acid batteries but they use glass mat between the plates for separation, I did read somewhere they run on a slightly higher Voltage.
Your 16 Volts is a worry, I know my stock OMC regulator limits the Voltage to just under 15 Volts.
Is your Voltmeter accurate?
Zero Volts could be a fault anywhere in the system but 16 Volts points to a faulty regulator, I'd like to think pull starting and running without a battery the regulator would still clip it to 15 Volts or less. I can't imagine OMC relying on combined battery load & regulator to limit the Voltage.
cfauvel -
Already bought the new reg...just haven't installed it yet.
the current regulator appears to be 6 years old...
is the volt meter gauge accurate? well not sure, really...if anything it reads on the low side....fully charged battery reads around 12v at the gauge and 13+ at the multimeter...so I would assume 16+ at the gauge might be closer to 17+....eeeks
Might be time to get a new volt meter gauge to be sure.....it is 31 years old....
I need to run the boat and have my meter handy to test at the battery when I see 16+....CDi does state that (had to hunt and peck to find it) the AGM would pull higher V from the regulator....I just don't get how CDI can't put something in the guts to cap it at 15V...or maybe they do , when new, but using AGM, it does something and breaks diodes in the reg to allow > 15v
Could be a loose cable somewhere too I guess...
read somewhere too that if you run the engine without the battery it would mess up the reg as the volts have no where to go...
Cfauvel -
Did some testing
1 - at the battery I have 12.9v
2 - at the starter solenoid I have 12.9
3 - undoing the big red plug by the motor I have 12.9
4 - at volt gauge I have 11.7, the gauge is using the purple ignition wire .
5 - tested purple wire all the way to the horn and there too it is 11.7
6 - tested a power distribution strip and was around 12.86
so somewhere between the big red plug at the motor to the horn I'm losing 1.2 v
and the gauge is accurate as it displays slightly less that 12V mark....
Should I change the gauge's sender wire to be from the distribution strip instead...as the distribution strip is getting power directly from the battery ?
FED -
11.7 Volts on the Purple is low, it should read very close to battery Voltage with only instrument loads on it.
The Purple wire is fed from the solenoid positive (red) via the fuse where it changes to red/purple, via the red plug, via the key switch where it changes to straight purple.
It sounds like in addition to the 16 Volt problem you may also have a dodgy connection on the purple or purple/red or fuse or red plug or key switch.
I think I'd compare the meter against a known good one or buy a new one, gotta start with a base line.
No because then the gauges would be ON all the time.
cfauvel
I am pretty confident the gauge is reading right as it lines up with my multimeter...BUT why is there 1.2 v drop from motor to horn....I HATE removing the key switch...a real PITA removing the gimble mount to get to it.. But I want to see if there is 11.7 behind the key switch....I am pretty sure there is...
more likely like you said...something at the motor end where red turns into purple....gotta find that.
FED -
Follow the small red wire on the positive side of the solenoid ---> fuse ---> red plug...
I have to say being a constant 1.2 Volt drop it does sound like straight out voltage drop along the red/purple wire BUT with only the gauges on it seems very large.
You could unplug your accessory harness and measure it there at the controller, that should take all the load off it.
Voltage drop is proportional to current, halve the current you halve the voltage drop.
cfauvel -
Will do
I have the following gauges
Tach (with light that works)
Volt (light doesn't work_
Hour (which doesn't work - couldn't that be the draw, light doesn't work)
Fuel Flow (navman f2100, back lit)
two fuel gauge (both lights work)
you lost me there, sorry.
