1986 120 Evinrude help needed
Cudos
Ok guys heres the problem. 86 120 looper starts fine. Seems to idle ok, runs at low throttle good, runs wot good, but try to run a 1/2 to 3/4 throttle and she will start to sputter and die. I then have to choke (prime) to get her going again and make sure I go to wot to keep her going.
If I go from wot to neutral she will idle fine and then I can bump the throttle up until I hit the 1/2 way mark. If I don't continue on to open her up she will crap out.
Any thoughts?
Thanks
Daviet
Re: 1986 120 Evinrude help needed
Almost sounds like it's time to overhaul the carbs maybe.
