Welcome to drydock, Trev,
The mid 80's Wellcraft center consoles were known to get soft decks, especially around the console area, transom, and gunnels. I believe its built with a wood core transom, wood core deck, glass wrapped wood stringers/bulkheads, and floatation foam. The factory did a poor job of sealing fittings attached to the deck, so water eventually finds its way in. You may have other problems below, like wet foam, compromised stringers and transom.
The proper way to fix your problem is to cut the cored deck out all the way around, leaving about a 2" lip against the edges, if its a tub style deck.You have to remove the console, and have to cut it out in a few larger square pieces, because its HEAVY. The you can check the foam, stringers, and transom. Good time to address the fuel tank, its 30 yrs old
Probably not what you want to hear, there are other ways to attack it, but above is what's recommended.
Basic materials would be Resin, glass cloth and mat, quality ext plywood, Cabosil, PPE, Gel coat or paint, and consumables.
