1985 tilt/trim dont work in water?
Rich1540
1985 50hp
model 507x5a
serial 1916
usmarine
ok trim works on land great ,but when in the water it dosent work only when trolling slow! how can i fix this ,do i have fill the oil if there is oil?
it looks like a big electric wire going to it!
RRitt
Re: 1985 tilt/trim dont work in water?
you probably have a tilt system ... in which case it is doing exactly what it is suppossed to do. If, on the other hand, you have a trim system that fails under power but does not bleed down then the most likely cause is the bypass valve in your tilt ram. A valve body failure would bleed down.
Rich1540
its says prestolite and has an oil fill plug on the side! its mounted on back of boat and a cylinder runs to side of motor bracket ! is this just tilt?
RRitt
tilt looks like a shock absorber. It is prefectly round, tall, and skinny with a mounting eye welded onto the end of a shaft.
trim looks like a floor jack that is missing the lift arm. It is short and squat with either a square or five sided shape. It has no mounting eyes. Just a fat little shaft that pushes out a few inches.
Look under your engine and see what you got.
Rich1540
i have nothing under motor, so must be tilt, looks like a shock !
thanks alot for the responce really appreciate it!
