1985 Mirrocraft Breakaway
Status
Not open for further replies.
redneck joe
17' and she is in the driveway.
redneck joe
more later, gotta run the trash off and do some work that pays me money.
redneck joe
was a bit frosty this morning and as you can see the cats checked her out.
redneck joe
the people he bought from had painted the keel form the bow eye to about 4 feet down. It is a heavy coating but seems to have adhered well.
redneck joe
i'm surprised that there are not more dents; the dock rash is EVERYWHERE
the other side is just as bad. Painting for sure.
redneck joe
i like the home made back bench - as you can see it appears thy cut up some pontoon railings. Looks like a poor patch underneath but that is an easy fix.
redneck joe
Not going to do a whole lot to this one, it will be a fishing / fun boat plus it is in way better shape than the Lone Star. Sand and paint for sure on the sides. The underneath looks fine.
A smart man would pull the 75 of the Lone Star (I think all cables will work lengthwise) and already have a good running kicker as well. Then sell the Lone Star and most likely even after some other work come out ahead. Will miss getting comments at the ramp on the LS though.
A stupid man will look for something at the 90 max rating to put on, maybe even like twins. That would be cool.
I was able to pick up at the stern so if there is foam appears not to be waterlogged.
Floor is solid, looks to have been replaced (diff carpet on the floor versus sides) but maybe not screwed down to well? I can see at one of the seams where it is curling up. Feels to be about 5/8" ply which is what the bench seat is made of.
The cap is carpeted, worn thru on the bow a bit and glue is turning loose on the cap. Initial thoughts are to cut that out and roll on some bedliner type material that has some grip to it.
All three seat are fine, one small rip in one. I'll probably make custom cushions for the bench and the bow area and only use the third seat for fishing. I plan to drop in a 3/4? decking for a fishing seat up there, removable when out for fun. Need an electric trolling motor.
It already has 4 rod holders. Only one beer holder?
It has a black plastic steering wheel, I hate those will change that out.
Trailer is serviceable, tires have a few seasons of life in them but unfortunately they are diff sized that one on the LS so cannot steal my spare off. New one has no spare. Plus my wheels and tires are too big to fit into the space avail under the fenders.
Need slight adjustment on the bunks, they are hitting the chines a bit off.
So ? there you have it, probably will be a slow roll on this one but you never know. Plus before I put the LS out there I have to replace the one bad section of floor. Not going to put out something with a soft spot on it. That will be a long weekend project to pull and pattern and gluing new vinyl etc.
GA_Boater
Talk about screwed up priorities! It should be 1:1!
Is the black stuff on the bow sprayed undercoating? A bow leak to be looked at maybe. All in all, not bad, Joe.
redneck joe
Yeah GA it is something like that. It's way thicker than paint but not as thick as bedliner stuff. I'm thinking that stuff on tv where they cut out the bottom of a boat and put in a screen coated with this
redneck joe
Plustrolling motor plus depthfinder plus a couple guages oh and plus steering cable. Etc.
jb the motor is your extertise. How many cylingers, is it a heavy 90, etc.
Status
