1985 Mercury 115 6 cylinder sparks issues.
JJ8191
I have spark on 1,3,5 but not 2.4.6. I have swapped stator wires , trigger wires, and replaced the bottom switch box all with the same results.
jimmbo
Mercury recommends replacing both switchboxes, something about a biasing issue.
JJ8191
Did that both switch boxes are brand new. I jumped the tigger to from the top to the bottom with same results and did the same with the stator. I am at a lost with it
JJ8191
Yea I bought two so just did the bottom one since the top one was working. After I posted I was reading that the top one could effect the bottom one so I replaced it but had negative results.
JJ8191
Thanks for the website had helpful pointers will try it out and let you know. It's looking like try the replacing the flywheel I spare engine for parts so will try it out. Might try the stator put I all ready swapped leads form top to bottom and still have the same problem.
JJ8191
Still no luck, swapped stators fly wheel and trigger and same result no spark on 1 3 and 5.
JJ8191
I just replaced the stator and trigger both are CDI products still have the same results. Bottom switch box not working.
Faztbullet
The top pack could have had the bia's problem and damaged the new pack you installed then the new damaged pack damaged remaining new pack..
