1985 MerCruiser 190
the dragon
Good morning guys, I have a 1985 MerCruiser 190 i/o in a 17 ft Baretta boat. I ran the boat last year and i noticed that the voltage gauge was only showing 11.5 charging volts at any speed. My guess it is the alternator. but there are no videos that show a step by step replacement of it. I have to put the charger on the battery the night before I take it to the lake. any help would be greatly appreciated. Dave
A manual is better than a video
Take a picture with your phone of the battery and alternator wiring (this will help you put it back)
Disconnect the battery wiring and remove the battery.
Take it in to have load tested
Remove the alternator wiring, then unbolt the alternator
Take it in to have tested
Replace/repair as needed
Replacement is reverse of removal
Dubed
This is a 3.7 190?
There is no alternator unless someone upgraded. If you have the original system, time to upgrade
stresspoint
Oh no , the worlds gone back in time too the 80s , nothing step by step on how to get an alternator off and back on again,
step 1, get a manual > google search.
step 2 , locate alternator section and use manual to test , remove and replace alternator if found to be faulty.
the dragon
This is a 3.7 190?
yes it is a 3.7 190, if there is no alternator then how does it recharge the battery, also what upgrade do I need
there is a stator assembly under the front damper pulley. there is a really really expensive water cooled voltage regulator at the back of the block near the head. if you overheated it, you will most likely have taken out the voltage regulator.
the normal fix for the 470 motor was an alternator conversion. If yours has the original regulator, it lasted 20 years longer than most.
Alumarine
This is what the alternator would look like if yours has been converted.
It's the silver object on the left. It might be higher than that.
Picture from breezeworks site.
ROY WILLIAMS
I was the MCM470 Mercrusier 1978 engine 3.7L ....... the regulator of the damaged it ...30 years ago ..... then the alternator updated it 1990.... did the video >>>>
the dragon
okay here is a dumb question, if the stator is still good and the regulator is bad can I just change out the regulator and how do you test to see if the stator is good
Scott06
Don't know how you can test it but yes you can change out the regulator if you can find one. In addition to being trouble prone, I believe they are NLA hence the alternator that most folks do.
Dubed
The cheapest way out is to replace with an alterator kit. If you can find a regulator, they are big money. Plus, the stator probably wont be too far behind. Breeeworks has a conversion kit delivered, under $400. Plus Kevin is great to deal with, and he has other parts in stock you will be needing for that 3.7.
the dragon
do you have Kevins phone #
There are test procedures in the manual
If I owned a 470, I would be tempted to take a $30 40 amp gas powered welder regulator and mount it to a water cooling plate to replace the NLA water cooled regulator
ROY WILLIAMS
the stator/and regulator semi conductors a damaged MCM470 of my 1978.
now my MCM470 of that updated it alternator ///...year 1990 ....
damaged is stator/regulator ...
ROY WILLIAMS
my regulator 1987 is the cost 130 dollars ...3 years damaged it .... then the alternator ....1990..
Bt Doctur
the stator supplies about 40 volts AC to the regulator ,its there its rectified to DC voltage and regulated
