1985 Merc 150 hp v6 outboard no spark
Mike Schilling
I am having a problem. I replaced the jets on my engine and the oil line from the injector as well. When I reassembled, there is no spark to any of the plugs. There are two black boxes that control 3 cylinders each.I doubt they both could go like that, so assume there must be a broken wire somewhere. I checked kill switch on control and it seems to be functioning. Is there something simple I'm overlooking? I do have a SELOC manual, but most items say test by substitution. Is there a common wire that may be broken?
Is there a no spark troubleshooting flow chart?
Thanks.
Barnacle_Bill
Re: 1985 Merc 150 hp v6 outboard no spark
Did you check to see if you accidently tripped the emergency kill switch?
Mike Schilling
I did check the kill switch, and it tests fine. I do have a Seloc Mercury 1965-91 manual, but there is not much troubleshooting when it comes to no spark on any of the solid states.
Laddies
Banned
Here help from CDI
andy6374
Disconnect the wiring harness and jump the stater solenoid.
Mike Schilling
Thanks for your help. Removed yellow wires from rectifier and it fired right up!
On my way to get a new one. Appreciate the help!
