ok I figured it out. I got everything back totogether, and I was able to get it started. It dies out after little while. Im guessing everything needs to be adjusted. I have one problem. My fuel pump is mounted on the air box, but the powerhead I put on had the fuel pump mounted on the crank case. So my vacuum line is not connected. How can I get a vac line to my fuel pump? My old powerhead had a nipple to connect to, and this one doesn't.
